Upgrade to Premium
Yamaha: Boosted Sleds (Turbo or Supercharged) Turbo discussion for Yamaha aftermarket Turbo or Super Charged sleds.
Reply
  #1
Old 11-21-2017, 07:28 PM
skibob1 skibob1 is offline
Currently: Not set.
skibob1 is an unknown quantity at this point
Default phazer boost leaks need help thx
need help phazer mcx no head shim. checking for leaks found one on a vent line fixed that. when i pressure the system do i need to plug the exhaust? i have air coming out of it thx
Rate this post: Yes | No
  #2
Old 11-22-2017, 12:12 AM
Currently: Not set.
Default
found out i needed to be at tdc.
one more question though, would i have any issues if there are leaks in the pipe from the exhaust to the turbo.
who ever installed it has a lot of pin hole leaks in the weld right before the turbo.
should i re weld it up? thx
  #3
Old 11-22-2017, 08:48 PM
motojunkie101's Avatar
motojunkie101 motojunkie101 is offline
Currently: Yamaha 4 stroke moderator
MODERATOR: Premium Member
motojunkie101 has a reputation beyond reputemotojunkie101 has a reputation beyond reputemotojunkie101 has a reputation beyond reputemotojunkie101 has a reputation beyond reputemotojunkie101 has a reputation beyond reputemotojunkie101 has a reputation beyond reputemotojunkie101 has a reputation beyond reputemotojunkie101 has a reputation beyond reputemotojunkie101 has a reputation beyond reputemotojunkie101 has a reputation beyond reputemotojunkie101 has a reputation beyond repute
Garage
Default
yep, you want to seal that up.
__________________
Quote:
Originally Posted by Himark View Post
"hold still I saw this on Snowest"
Bad decisions make good stories
2015 Yamaha Viper 162 SE/MPI turbo
Days until I retire
  #4
Old 11-23-2017, 01:02 AM
Currently: Not set.
Default
thx
  #5
Old 11-26-2017, 12:17 PM
stingray719's Avatar
stingray719 stingray719 is offline
Currently: 2014 Viper MTX conversion
stingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond repute
Default
Phazer were notorious for late boost and poor power due to the stock secondary clutch that came from the old 2 stroke Phazer. Put a real Yamaha secondary on it and you will be amazed. Info on the web on how to get a SRX or Vmax secondary on it.
  #6
Old 11-29-2017, 11:09 PM
Currently: Not set.
Default
thx will look into the clutch
  #7
Old 01-03-2018, 12:29 AM
Currently: Not set.
Default
still have some leaks where rhe gaskets are from the header to the y pipes. bought the new thicker copper ones and it still blows out air there. any tips would be great! any sealant work? any other joint reworking or fab fix help it out. have a trip comming up in 8 days to cooke city.thx
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — working on my leaks Thread Starter — hawktoy85 Forum — Arctic Cat: TURBO Replies — 3 Last Post — 02-03-2014 11:26 PM
Thread — apex boost leaks Thread Starter — boost mod Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 13 Last Post — 03-03-2012 10:16 PM
Thread — need help checking for boost leaks Thread Starter — yammi4ever Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 1 Last Post — 12-19-2010 08:19 PM
Thread — exhaust leaks Thread Starter — dobson Forum — Performance/Modified Replies — 6 Last Post — 01-28-2009 01:41 PM
Thread — boost leaks... Thread Starter — tube Forum — Performance/Modified Replies — 6 Last Post — 11-11-2008 11:41 PM
