Upgrade to Premium
Reply
  #1
Old 08-12-2016, 10:34 AM
Speed Shop Inc.'s Avatar
Speed Shop Inc. Speed Shop Inc. is offline
Currently: Not set.
Speed Shop Inc. has a reputation beyond reputeSpeed Shop Inc. has a reputation beyond reputeSpeed Shop Inc. has a reputation beyond reputeSpeed Shop Inc. has a reputation beyond reputeSpeed Shop Inc. has a reputation beyond reputeSpeed Shop Inc. has a reputation beyond reputeSpeed Shop Inc. has a reputation beyond reputeSpeed Shop Inc. has a reputation beyond reputeSpeed Shop Inc. has a reputation beyond reputeSpeed Shop Inc. has a reputation beyond reputeSpeed Shop Inc. has a reputation beyond repute
Default ProLite HD Jackshaft for 2016-2017 Arctic Cats, -2 lbs
Our jackshaft for the 2016-2016 ProClimb is not only 2 lbs lighter than stock but its also stronger than stock. It is a direct replacement for the stock one, but also is threaded on the end for more strength when installing a belt drive. The bolt and machined washer will hole the top sprocket firmly against the shaft. The stock snap rings can allow the top belt drive sprockets to wobble, wear out the spline, and cause premature belt failure. So using this shaft has several benefits.
In the picture, the larger diameter version is our version. The fit the 6000 and 8000 models. And we do have a limited number of Reverse models versions for the 5000, 7000, and 9000 models.
The picture with the three shaft ends shows the end of the reverse model too.
http://www.bd-xtreme.com/index.php?i...eme_font=font7
Click image for larger version
Name:	SSI 2602-778BD Jackshaft.jpg
ID:	271633   Click image for larger version
Name:	SSI 2602-778BD Jackshshaft End.jpg
ID:	271634   Click image for larger version
__________________
Black Diamond/Speed Shop Inc.
6238 318th Street, Cannon Falls, MN 55009
www.speedshopinc.com
www.bd-xtreme.com
Email: sales@speedshopinc.com
ph 507.263.2244
Rate this post: Yes | No
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2016 ST vs 2017 Raw Thread Starter — Yaeger34 Forum — Snow bikes Replies — 6 Last Post — 01-19-2017 11:07 AM
Thread — 2016 Front End or 2016 Clutching/Jackshaft/gears Thread Starter — j.janke Forum — Arctic Cat: Proclimb M Replies — 25 Last Post — 10-27-2016 09:02 PM
Thread — PROLITE CHAINASE COVER AND OIL TANK, ONLY 2 LBS Thread Starter — Speed Shop Inc. Forum — Arctic Cat: Proclimb M Replies — 17 Last Post — 08-18-2016 04:35 PM
Thread — PROLITE CHAINCASE COVER AND OIL TANK-ONLY 2 LBS Thread Starter — Speed Shop Inc. Forum — Black Diamond/Speed Shop Inc Replies — 0 Last Post — 08-12-2016 10:13 AM
Thread — 2016 vs 2017 Thread Starter — RevXRider Forum — Polaris: AXYS Replies — 23 Last Post — 03-08-2016 04:15 PM
no new posts
