Upgrade to Premium
Arctic Cat: Powder Special and older 2000 and older, all models in the Powder Special chassis and older chassis models
Reply
  #1
Old 12-23-2014, 01:33 PM
Irideyamaha Irideyamaha is offline
Currently: waiting for winter
Irideyamaha is an unknown quantity at this point
Default 2000 Powder Special Carbs vs 94ZR Carbs
I picked up a motor from a 2000 Powder Special 700 yesterday to fix my 94. Im wondering if the slide style carbs from the new engine will work on the older style motor. They have an electical plug and i dont know if that will make any difference in how they work if its not hooked up.
Any help would be appreciated.
Rate this post: Yes | No
  #2
Old 12-24-2014, 05:20 PM
Default
no one knows what im speaking of?
  #3
Old 12-24-2014, 05:58 PM
clutch clutch is online now
Currently: WTF mother nature?
Basic Member
clutch has a reputation beyond reputeclutch has a reputation beyond reputeclutch has a reputation beyond reputeclutch has a reputation beyond reputeclutch has a reputation beyond reputeclutch has a reputation beyond reputeclutch has a reputation beyond reputeclutch has a reputation beyond reputeclutch has a reputation beyond reputeclutch has a reputation beyond reputeclutch has a reputation beyond repute
Default
They could be used, but there are lots of differences. Single throttle cable instead of dual, different mounting flanges may not work with the older airbox. The electrical plug is the tps that you don't need if you are using the 94 ignition. Jetting would need to be sorted out as the new engine has altitude compensated carb, and single pipe.
The Following User Says Thank You to clutch For This Useful Post:
Irideyamaha (12-24-2014)
  #4
Old 12-24-2014, 08:34 PM
Default
Thanks clutch that helps a lot. I'm running kickass filters so the airbox shouldnt be an issue.
Dont really know much about altitude compensation, would the main jets be fairly close to the old carbs or will they be way out? Just wondering where a guy should start.
  #5
Old 12-24-2014, 09:09 PM
Basic Member
Default
Jetting is way different in the newer flat slide carbs. If you are not hooking the altitude compensator up that makes the jetting in those carbs the same as sea level specs. I ran twin pipes on my 700ps and if memory serves think I ran 270 main on pto, and 260 on mag at 8-10,000 feet. I would start around 280 or so and jet from there. I guess I don't know your location, so that will play into your set up.
  #6
Old 12-24-2014, 11:25 PM
Default
  #7
Old 12-24-2014, 11:27 PM
Default
Tried to post from my cellphone so i might have double posted but thanks again.
was doing the crank seals tonight and ran into this. Should a guy put it back together like this or should i see if one of my other cases is in better shape. Dont want to do the crank bearings too badly. Hoping the damage will just line up like it was before without a problem.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 3x 38mm Mikuni carbs from 1996 XLT Special with extra jets Thread Starter — snowplease Forum — Carb/Airbox/Reeds (Swapmeet) Replies — 0 Last Post — 09-08-2012 10:06 AM
Thread — 2001 rmk stock carbs, and 1998 skidoo carbs Thread Starter — Rammit Forum — Carb/Airbox/Reeds (Swapmeet) Replies — 0 Last Post — 05-10-2010 10:26 PM
Thread — 01 800 zx carbs vs 03?,04 & newer carbs: main jet style differences & other changes Thread Starter — flatlander72 Forum — Performance/Modified Replies — 6 Last Post — 01-16-2009 04:56 AM
Thread — Cowl from 99 Powder Special Fits Powder Specials, ZR's from 1997-2000 Thread Starter — coloradoman25 Forum — Hoods/Windshields/Belly Pans (Swapmeet) Replies — 0 Last Post — 10-26-2008 09:01 PM
Thread — Lectron carbs 44mm snow carbs great shape 275.000 Thread Starter — njjs Forum — Carb/Airbox/Reeds (Swapmeet) Replies — 2 Last Post — 10-10-2008 04:20 PM
no new posts
