Mostly RT Parts, with a few misc. Rev and S-Chassis Parts
Marty UT
Stirring the pot
34,200
9,322
66
Utah
Time to clean up the garage!!!
A few years back I broke a connecting rod in my RT and caused quite a bit of carnage. The damage was not repairable so I ended up getting another engine. Since that time the old engine has sat on the workbench taking up space, and it's time for it to go!! It will be easiest to list what isn't good, everything else is up for grabs. I am just starting the cleanup process so please bear with me until I can get pictures and prices up. In the mean time I'm willing to accept reasonable offers on parts and can get pictures posted of those parts as needed. Also I will try to respond as quickly as possible to your posts and PM's, but life is busy right now, so don't get discouraged if it takes a day or 2 for me to get back to you. I want this stuff gone, so I will respond, it just may or may not be right away. Engine had about 1600 miles on it.
Ok, so the parts of the engine that are not good are:
Top half of the crank case
Cylinders
Half of one reed valve
Pistons
One Connecting Rod
Parts that have been SOLD:
Bottom half of the crank case
Water Pump and Housing
Oil Pump
Water/Oil Pump Shaft
Rave Valve Assembly
Fuel Rail and Injectors
Balance Gears
Piston Pins
Throttle Cable
Those are the parts I know for sure are not usable. The crank looks to be in good condition from what I can tell. There are a couple of marks/nicks on it from flying debris when the connecting rod broke, but other than that all the bearings move freely and everything else seems to be fine. Obviously you would want to have it checked out before using it, but I just want to put out the information I know. As I disassembled the engine I just threw most of the bolts into a bucket, so if you need any of those I would rather just get rid of those as 1 lot. I won't know what bolt goes to what at this point.
That pretty much covers the engine. I do have a few misc. oil lines, coolant hoses, coolant reservoir and the engine mounts as well.
Other RT parts:
Blue Trunk assembly - $50 + Shipping
Blue (clutch) Side panel - $50 + Shipping
Yellow Knee Deflectors - $15 + Shipping
Yellow Snow Flap - $25 + Shipping
Sway Bar - $20 + Shipping
Ceramic Coated "The Thing" Can - $65 + Shipping
Rev parts:
Yellow Trunk assembly - $50 + Shipping
Running Board Reinforcement Kit - 861804300 (Never used, In open package) - $50 + Shipping
Parts that may fit Rev OR RT (Buyer is responsible for fit verification):
515175943 - Tachometer - $50 + Shipping
515176478 - Tachometer - $50 + Shipping
515176477 - Speedometer - $100 + Shipping
861509300 - Lens and Reflector Kit (This is a clear lens with a red inner lens) The lens is used but the reflector was never used. - $20 + Shipping
S-Chassis Parts: (all came from a 1996 MXZ 670)
Engine Torque arm (Minus the rubber bumper pad) - $10 + Shipping
White Face Tachometer - $25 + Shipping
Black Face Speedometer (Odometer works, but Speedometer Needle does not) - $FREE + Shipping
Black Face Tachometer - $15 + Shipping
Pull Start Trim Panel - $5 + Shipping
Brand New (take off) Driveshaft assembly with drivers - $100 + Shipping
Heat exchangers (pair) - $100 + Shipping
Cover for a 2-up S-Chassis Sled. Used for about 2 years. A bit faded, but otherwise in good shape. - $50 + Shipping
That's about all I can think of for now. I will add more if I come across it. Pictures are posted below, and I will also add more pictures as time allows.
Yellow REV Trunk
Blue RT Trunk
CKX Helmet w/ Heated shield - $100 Shipped
S-Chassis White Face Tachometer
S-Chassis Black Face Speedometer (Odometer works, but Speedometer Needle does not)
S-Chassis Black Face Tachometer
S-Chassis Pull Start Rope/Handle Panel
S-Chassis Drive Axle Assembly (9-Tooth Drivers)
