Upgrade to Premium
Ski-Doo: ZX Sleds 99-2005, all models in the ZX chassis
Reply
  #1
Old 01-21-2010, 08:14 PM
ScottySnow ScottySnow is offline
Currently: Not set.
Basic Member
ScottySnow is an unknown quantity at this point
Default LED Tail light
Has anyone tried a led tail light on there zx? If so where did you get it? any pics?
Rate this post: Yes | No
  #2
Old 01-22-2010, 01:25 PM
Alberta Boy Alberta Boy is offline
Currently: dreaming of deep POW!
Basic Member
Alberta Boy has a reputation beyond reputeAlberta Boy has a reputation beyond reputeAlberta Boy has a reputation beyond reputeAlberta Boy has a reputation beyond reputeAlberta Boy has a reputation beyond reputeAlberta Boy has a reputation beyond reputeAlberta Boy has a reputation beyond reputeAlberta Boy has a reputation beyond reputeAlberta Boy has a reputation beyond reputeAlberta Boy has a reputation beyond reputeAlberta Boy has a reputation beyond repute
Garage
Default
yup... grab a 7 bar from a auto parts store and wire it in... I used a trailer "flat 4" wiring harness because it was easy to wire and cheap... get rid of the stock connector as you will never find another connector to fit. Here is my custom gas rack with LED on it... Sorry pics aren't that clear. I may have a picture of the same rack on my Polaris (kept it and powder coated it to match my Doo).
  #3
Old 01-23-2010, 01:12 PM
Currently: Not set.
Basic Member
Default Light
It looks good. Its small and out of the way.
  #4
Old 01-23-2010, 01:20 PM
Basic Member
Garage
Default
Quote:
Yup... the only issue I would say with having LED lights is that they don't put out enough heat to melt the snow when playing in pow all day... I wipe them off before heading down the trail at the end of the day but other than that I think they work great and way cleaner look than stock
  #5
Old 01-25-2010, 12:56 PM
LB_ LB_ is offline
Currently: Not set.
Basic Member
LB_ is an unknown quantity at this point
Default
I find the heat off the tunnel exchanger melts all the snow on the light anyway.
Oh ya,...and get the larger light bar. Mine doesn't emit enough light.
Click image for larger version
  #6
Old 01-26-2010, 09:01 AM
Basic Member
Garage
Default
Good call... you can grab ANY LED light and mount it... going with a bigger one... either double row of 7 lights or 15 lights straight across the back of a gas rack would be cool too and you would see it better... the only issue of mounting them on a seat is if you put your jerry can on the back of your tunnel, you block your light...
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
no new posts
