BigAir Well-known member Lifetime Membership Nov 26, 2007 1,748 214 63 Montana Oct 9, 2017 #1 Installing a clutch kit in my 2016 T3. Is it worth sending the clutches off to have them balanced? If so, any recommendations on who to send them to?
Wheel House Motorsports Well-known member Lifetime Membership Nov 27, 2007 29,933 5,968 113 34 SW MT Oct 9, 2017 #2 You don't need to but its not a bad idea. I believe big jon @ SHR does, also indy specialties (not sure if he does doo ones). cascade clutch and performance does them as well. good luck out there josh!
C caper11 Well-known member Nov 2, 2008 2,055 2,170 113 Northern alberta Oct 17, 2017 #3 Nope it does not need to be balanced after a kit is installed. You can get it balanced if you wish tho. Sent from my iPhone using Tapatalk
S SnoKing Free Member Nov 28, 2007 131 23 18 Pence, WI Oct 18, 2017 #4 If you didn't mark the 2 sheaves to put index them back in the same orientation the balancing could be off. I always weigh each new weight to be sure they are the same before installing.
S slednfool Free Member Jan 15, 2008 38 11 8 North idaho Oct 21, 2017 #5 Balancing definitely made my last etec idle smoother:face-icon-small-win
