The price of this kit is very very appealing to the consumer, however i have some concerns and it seems clear why its so cheap, my thoughts/questions in blue
Kit includes:
•G-28 V band internal waste gate turbo, with 8 psi actuator •2.5" polished stainless steel exhaust with quiet stainless muffler
thats a cheaper knock off turbo, not a garrett. however, this is where i wont agree with most, the cheap knock off turbo will be just fine, the garrett is a bit overkill. I assume the actuator is not adjustable? running 8lbs of pump at lower elevations will surly make the top end go boom, not sure i agree with the smaller 2.5 exhaust as the waste gate flow will not flow so easy, not a huge deal, but not optimal. the stainless looks great, but it wont look like that after it gets hot
•PUSH TURBO TUNED EFI controller with 4 injector connectors
Whats the base controller?
•BDX adjustable blow off valve
•Equal distribution and high flow air box
equal distribution? so 10psi in a 2" tube flowing two separate intakes is not equal? i understand where this point is derived from, and it wont allpy in a sled application, flow is far to minimal to matter
•BDX in tank 1-1 rising rate fuel pressure regulator with new spring rate
what about the stock fuel pump itself, the other kits that cost more come with a high volume fuel pump that wont crap out like the stock one will
•New light weight oil system with the industries first liquid cooled oil tank and turbo
i see some square bar used as a oil tank, sure hope she still sees some oil inlet while the sled is on its lid. can someone explain how the oil is cooled or why it would matter
•New billet light weight air filter with Outerwears pre-filter
•New billet gauge holder that mounts on bars includes:
• Oil Pressure Gauge
• Fuel Pressure Gauge
• Boost Pressure Gauge
Where is the A/F or EGT??......surely you dont think its ok to not run without either??
•Plug and play electronics and components, no wire splicing or tapping
•Kit comes 80% preassembled
•1 year warranty against manufacturer defects
Other parts to make any turbo kit functional:
- clutching spring/weights/cam
- vents on the dash
- A/F or EGTs
