HAS ANYONE USED GRIPLOCKTIES RUBBER LINED CABLE TIES?
mountainhorse
18,606
11,814
West Coast
www.laketahoeconcours.com
These things look pretty cool.... I like the adjustability feature for setups and then trim for final.
I know a lot of regular "zip" ties can and have cut into the insulation on the Polaris sled harness'.
A bit pricey... but I really don't skimp on cable ties.
HMMM.
https://www.griplockties.com/
<iframe width="853" height="480" src="https://www.youtube.com/embed/rQvNKxS4yCk" frameborder="0" allow="autoplay; encrypted-media" allowfullscreen></iframe>​
kidwoo
2,630
1,875
Those ridges also look like rubbing points since they're raised.
make JJ_0909 try them first.
kanedog
Undefeated mountain clutching champ of the world.
3,112
3,872
I wish the cops used these instead of the normal zip ties they use.
Sent from my SM-G920W8 using Tapatalk
J
JJ_0909
ACCOUNT CLOSED
Nov 16, 2009
1,023
1,033
I actually think these are way cooler for mountain biking...no more frame scuffing when you are too lazy to route your cables internally ;)
kidwoo
2,630
1,875
Was definitely thinking the same.
dibs on the idea to buy all the pretty colors and sell them at a huge markup to the color coordination crowd.
mountainhorse
18,606
11,814
West Coast
Here is a great write up from Diamond Dave from the past.
The "teeth" of the ties actually cuts into the wires.... the polaris stuff is pretty soft and not resistant to abrasion very well.
This is where I think these would shine... especially on the handlebars and engine.. where a lot of "buzz" vibration is going on.
I've ordered a few packs of these.
Another thing to watch out for...The factory wire ties that hold the hand grip heater wiring to the bars is wearing through the black protective coating causing the wires to short out to the bars. The wire ties are way too tight.
Another area of concern I noticed while dealing with this problem is the insane amount of corrossion in the electrical connectors for the hot grips from the main wiring harness.
The pics were hard to get good but it will give you an idea of what is happening.
And then they wonder why there's blown ECM's...Fuses are necesaary, Hello???
diamonddave
Chilly’s Mentor
5,577
3,890
Wokeville, WA.
Just used them on a repairs on customers boat....top notch.
the ribs are rubber, designed for aircraft, to a much higher standard.
... no pics but have ordered more, so will do it then.
Great find brother...I forgot about looking into these. Where'd you find the best price, easiest ordering, etc.....???????
