Forgive me if I haven't followed all the threads on this, but is the 2010 M8 DD/bearing/or clearance slightly different than other models, thus requiring machining the shaft or some other non-routine adjustment to compensate for different clearances?
Yeah...I thought there was a problem with using the wider bearing on the newer cases? If I remember right the original skinny bearing lets part of the shaft on the gear stick out and there is a hollow spot on the case it goes into. When using the wider bearing the bearing is flush with the shaft on the gear so hits the case when you put the cover back on. I thought some guys were having problems with this?
I just talked to BDX last week because I couldn't get a straight answer any where. On a 2010 they recomend to completley pull the DD, and machine .055"-.075 off of the DD end of the track shaft. If you don't do the machining and just take loose the trackshaft bolt your gears will overhang each other and there will be binding in the case.
Final answer!
Ok, so the BDX bearing kit for 07+ diamond drives HAS the wide bearing?
This is the kit I ordered:
http://bd-xtreme.com/bdxdiamonddrivebearingkit07-upreverse.aspx
So I'm going to have to have my drive shaft machined to take ~0.015" off in order to get the proper tolerance?
Or, I can go to NAPA and get a 4203 bearing and it will fit no issues?
Will be on an 09'.
Seem to remember reading that the 4203 is a straight drop in for the 2010 it is slightly smaller than the 5203,anybody know if this is correct?
Ok, so on a 2009 with the BDX bearing I have to machine the shaft, if I go to NAPA and buy a 4203 bearing I don't.
Guess I'm gonna go for th 4203 because I really don't want to have to machine the track shaft
