Upgrade to Premium
Reply
  #1
Old 01-11-2018, 07:59 PM
MTN_VIPER's Avatar
MTN_VIPER MTN_VIPER is online now
Currently: Making roll-over valve kits and ROVCMs
MTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond repute
Default New Sidewinder roll over valve kits
I have been receiving quite a few requests to build a ROV kit for the Sidewinder. With that in mind, we have designed a ROV kit for the Sidewinder that replaces the normally closed OEM check valve with a normally open system similar to our Viper ROV kits.
Just like our Viper ROV kit, the Sidewinder ROV kit is a premium unit that features a Roll Over Valve Control Module (ROVCM) and the quick prime oil pump re-prime system!
I have more information at http://fourstrokesolutionsllc.webs.c...g-cat-rov-kits
and for installation photos here at http://fourstrokesolutionsllc.webs.c...bumid=16102135
__________________
Four Stroke Solutions LLC
Patented Roll-Over Valve Systems
ROV kits for M/XF7000/Viper with Quick-prime!
For Arctic Cat and Yamaha Sleds
Patents 8,225,766 8,528,516
http://fourstrokesolutionsllc.webs.com/
e-mail fourstrokesolutionsllc@hotmail.com
Rate this post: Yes | No
The Following 2 Users Say Thank You to MTN_VIPER For This Useful Post:
JustBoostIt (01-16-2018), Woody67 (01-11-2018)
  #2
Old 01-12-2018, 10:22 AM
Motorbreath_ Motorbreath_ is offline
Currently: Loving my Viper :)
Basic Member
Motorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond repute
Default
I didn't think the Sidewinder needed a roll over kit..?
  #3
Old 01-12-2018, 02:58 PM
MTN_VIPER's Avatar
Default
Quote:
The stock normally closed valve does work. However some of my customers were having trouble with the stock OEM unit freezing closed. Usually it happens when the sled sits outside overnight in below freezing weather. If it freezes closed and you start the engine, it can over pressurize the oil tank causing it to leak at oil tank halve seal. To repair the leak requires disassembling the oil tank and re-sealing it.
Our ROV kit uses a normally open valve which is in the venting position while the sled sits overnight. Because the valve is already open and doesn't have to change positions during a cold start, the breather system can start venting right away. This allows the warm air to flow from the oil tank un-restricted as soon as possible. Which in turn, thaws out any accumulated moisture in the breather line that may have froze.
Basically our system is a normally open option for Sidewinder owners who may be having a freezing closed concerns with the stock normally closed ROV!
__________________
JustBoostIt (01-16-2018), Motorbreath_ (01-12-2018)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — New King Cat roll over valve kits. Thread Starter — MTN_VIPER Forum — Arctic Cat: 1100 ProClimb Replies — 2 Last Post — 01-12-2018 06:04 PM
Thread — Roll-Over Valve kits for Proclimb M1100 from Four Stroke Solutions LLC Thread Starter — MTN_VIPER Forum — Arctic Cat: 1100 ProClimb Replies — 84 Last Post — 11-15-2016 07:42 AM
Thread — Roll-Over Valve kits for Viper/XF7000! Thread Starter — MTN_VIPER Forum — Vipers! Replies — 22 Last Post — 01-01-2015 03:31 PM
Thread — ROLL OVER VALVE ? Thread Starter — sledheadjake Forum — Arctic Cat: 1100 ProClimb Replies — 10 Last Post — 02-28-2013 12:00 AM
Thread — Roll-Over Valve kits are now Patented! Thread Starter — MTN_VIPER Forum — Yamaha: 4-Stroke Replies — 12 Last Post — 09-05-2012 11:15 PM
