2019 Alpha Primary clutch travel?
kanedog
3,112
3,873
Does anyone know the travel on the Cat primary clutch?
Can you use Polaris, Yamaha or Comet springs in it?
Sanks
kx250fvollmer
Nov 7, 2010
9
Total travel is 33mm. The secondary only moves 1 inch inch. But yes Polaris primary springs work. Not sure about Yamaha, I dont think they do though.
0neoldfart
968
574
Thorsby, Alberta
The Polaris or earlier cat springs will work, but they require a cup adaptor as the springs are shorter, and will be effectively a lesser rate then listed. Speed were makes a cup adaptor, or you can stack glide washers to make up the difference. Polaris black (100/300) works well.
CB.8
Skidoo hill crew
450
Colfax, WA
The Arctic cat 60/240 is almost a direct replica for the Polaris black it is just made to fit. Initial results are promising.
