R
Here is the current setup on my 09 crossfire 141x1.6 w/ 188 1.9 studs for competing in a local Hill drag which has a few turns in it. My wieght 160lb with gear
Skis - SLP Powder Pros widened out to 43" stance
Shocks - standard zero pros
springs - adjusted to my liking
Sway bar - In
Front skid shock - standard zero pro 3/4" pre load on spring
limiter straps - still in stock setting
front skid mounted in stock hole
rear skid springs - set on medium
rear skid mounted in lower hole
no blocks
Last year I raced with my sway bar in thinking it would help when getting through the corners. I prefer to ride with it out though...Sled seems to react better in bumps with no bar but I am concerned i may loose to much in the corners with the sway bar out. Should i leave the bar on the bench?
i also have my rear skid mounted in the lower hole to decrease ski lift going up hill. I would like to play with the limiters or add blocks to the rear to take away more ski lift but getting out of the gate is very important too. So i need some wieght transfer. I am happy with my sled in the holeshot the way it is. Just wondering if anybody can give me any general idea on how to setup a sled for suck a race.
thanks
Sway bar - In
no blocks
thanks
