With the ralatively slow air speed over the intercooler when climbing, would it be benificial to put a fan on it? How many watts can the electrical system deliver? Is there space for a fan?
type-a, I did all the EVO testing on the intercooler fan last year. We had digital aircraft thermal gauges with probes mounted in the charge tube between the turbo and intercooler and after the intercooler. Had a switch mounted for the fan to turn it on and off. Monitored the intake air temps with the fan on and off. We noticed a number of benefits with the fan.
1- Air intake temps during slow, tree riding boondocking were reduced 40 degrees. 180 degrees instead of 220ish.
2- On a long climb it takes a lot longer for intake air temps to reach the maximum. Max air temps were low 300's.
3- When coming down off a climb the intake air temps cooled down significantly faster with the fan on. Usually back to 120-130 which is the lowest we saw when the engine/turbo were warmed up.
4- The fan blows over 400CFM constantly. This greatly decreased under hood temps. IMO, the fan does way more than extra venting.
So, yes, the fan is worth it. We have EVO fans in stock.
Also did intake temps come down with the big chute/super chute kits Because the turbo is more efficient.
Correct, more air flow from bigger turbos help huge.
Good meeting you Kevin, hope you enjoyed the show.
Show was great. Cant wait to see what else Jim and the guys at evo have coming next.
