AMAZON PRIME has
VIAIR 85P Portable Air Compressor for under $30 one day flash sale
12 VOLT - 60PSI Max Working Pressure, engine must be running during use.
1.26CFM Free Flow @ 0 PSI
Portable air compressor powered by auxilliary power outlet. cigarette light socker
(The 85P can only be used if your outlet is rated to 15 AMPS/180 Volts or more)
Easy to read tire pressure gauge mounted on the compressor. Super bright LED work light included.
