Is your sled a chain case or belt drive? they have different rails because the belt drive uses a 2.86" pitch track which actually makes your Original track a 154. If its a chain case sled then it has a 3.0" pitch track and is a 156.
So to answer your question about the wheels... It depends. If you do put bigger wheels on you should also install an offset axle. If your wheels end up a 1/2" below your rails (hyfax) thats going to cause issues.
Well, my sled is an Axys SKS, with a chain case. It came with 2.6", 2.86 pitch track (snowcheck ordered).
Last year I ran a CE 2.5", 2.86, center ported 155",
I am putting on a CE 3", 3.0 pitch, 156", center ported, with a new driveshaft and 3.0 pitch drivers
I just compared part numbers for the SKS 155, 2.6" and the RMK 155, 3". The rails, rear wheels, and axle part numbers are all identical
