H
What is the measurement between the stock nytro rear suspension bolt holes ( c to c)?
some pictures would be great of a 162 or in my case 153 which i am leaning towards thanks
Just got the front bolt holes mounted tonight. For the type of bushings I made, to fit correctly I moved it ahead 2" but left it at the same height.
I will need to move my drop brackets forward as the rear hole will be right on the edge. Should have it complete monday when I get some more rivets.I will give an update to handling and post some pics then. Attack angle doesn't seem any worse than stock.
Whats the latest?
Do the cat skids work better in the yamys than they do in the cats? Cause you don't have to search very long in the cat section to see they don't like much about the skids. Or are the stock yammy skids just that much worse?
