T
Who is running a cat fox float rear skid in there turbo yamaha? And is it working alot better? Also close does it mount up the the same points as the yamaha skid?
If you are running a 162 skid you have 2 options. A 153 Cat skid bolts right into the stock Yamaha holes but with an 8 inch wheel it is only good for a 159 track. If you were to put on a 9" big wheel kit it would just take up the slack in the track.
M5
LEts see some pictures.
buying a longer track and just running bigger wheels is pointless. your paying more for larger track but the footprint is no different that the 159.
He already has the 162 track and was just looking for cheap skid options to replace the POS yami skid, with the 153 Cat option you end up with a setback and a great approach angle which is where the extra track goes the only reason for the 9" wheels is to take up a little extra track so he can tension the track enough using the stock Cat adjusters. If I were doing it I'd buy the Iceage rails etc etc but it'd cost 4 times as much. Like I said before he can go with the 162 Cat skid but its more work to install than the 153 and the 153 does work well.
M5
