860 Twin Turbo chassis rebuild
R
Revanator
Well after 4 years, 5000 miles, hitting 3 massive rocks, running with a bent nun, re-welded a-arm, and a bent front shock.... it was time for a rebuild!
Sled: 04' Rev race sled that Turbo Al built, custom built 860cc motor, twin 53 series aerochargers, AAEN pipe...
This idea of building a tube chassis came about when I was in mechanical engineering and we were designing models to do stress analysis on. Then after watching a few guys on here build their own chassis, I knew it was possible. Just had to design a chassis that was extremely strong.
R
Revanator
More Pics..
Since we have the etec turbo done, and the 872 Trygstad etec done, it was time to finish the tube chassis!
Dry run bolting the suspension in
R
Revanator
Finished details
Chassis turned out alright, dropped 35.5lbs of the sled just with changes in the seat, fox floats, and the tube tunnel.
All tube was 3/4 .035" wall 4130, from stress analysis chassis proved 153% stronger than stock tunnel.
Twisting test with a 4ft lever on the back of the tunnel 100lbs of force... stock tunnel would twist 15.6 degrees, tube tunnel was .5 degree.
Will be building a full tube XP chassis, incorporating all stock plastics, gauges.. will come with CP3 belt drive, timbersled front and rear suspension, estimated weight with what we do know is sub 380lbs, and will be over 150% stronger, and over 200% more rigid from solid works design!
Wheel House Motorsports
29,933
5,970
SW MT
they definately are a LOT stronger if you dont get to caried away with the weight obsesion.
3/4 .035 tunnels rock. super solid, drop good weight and are a LOT nicer then alum tunnels.
Scott
Scott Stiegler
69,618
11,737
W Mont
That is very nice.
Tell me about the engine and twin turbos? What is the 860 putting out? And what do the turbos do to those numbers?
Are you running low or high boost?
R
Revanator
That is very nice.
Engine is a one off build by TurboAl about 7 years ago, custom domes, pistons arent from a snowmachine... twin 53's. Engine started as a 01' 800, and I have right about 5100 miles since it was built. I run anywhere from 6-10psi, back in CO I run 7lbs on pump fuel, race fuel for anything higher. Up here in AK at 5lbs add a little torco.
Never have had it "dynoed" but it eats my dads Felker etec turbo up when he is at 10psi and I'm at 6. When I had a 136x2" track on it I could see anywhere between 84-93mph track speed when climbing. yes... the speedo is correct and checked!
