D
What fuel control boxes are people running on what sleds? How easy was it to install and tune? And, do you think it made a difference and was worth the money? Thanks for the input.
hold off if ya can...new controller around the corner apparently..you can tune every 50 rpm from 900 to 9000..i am waiting for more info..approx 550 canadian
Who's box?
don't know ..??...my engine builder just informed me its coming down the pipe ..its in use apparently..he said he will give me literature and availibility asap but he says it works very good and must be close with pricing already figured out
Can you make fuel adjustments in the field without a computer?Here are some pictures of the products I mentioned yesterday. The Power Commander plugs inline with the ECU using OEM connectors.
The Power Commander is Nitrous and Turbo capable but you will need to purchase the Multi Function hub to enable these functions.
The LCD display can log data and store information on a standard SD card. The data can be replayed in the field on the display or you can download the data to your computer and view the information in excel.
As for ease of use it is a little different than a boondocker and the other boxes out there. It does require that you have a computer to use our software. The snowmobile products mentioned above are the same as our Sport bike and Harley products so if you are familiar with these you won't have any trouble.
Part #'s
Wideband Commander (15-7002)
LCD Display (LCD-100)
Multifunction Hub (HUB-003)
