Been fighting with no start in the mornings or when the sled been left for a couple hours all weekend. The solenoid looks perfect no corrosion or loose connections. I have to cycle the key alot before it will start, and then I get the dam error code `12 crank sensor.
After it starts the first time I have no problems till it sits again.
I did put a roll over valve on the sled and strapped the wires to the same wires as the solenoid.
Is it on its way out or should I look else where.
thanks
thanks
