I
Need large drop brackets, I have an 09 m8' drop bracket, wondering if anyone has put on proclimb brackets into an m8. CR Racing has some nice ones for $250.
Are you talking about needing a stock one, or adding more drop?
The thing to do is move the skid forward with pc rails
I'm not sure what all your doing but the m would clear a 2.6 stock.
If you do the bolts, then both have to drop to maintain suspension geometry. If you do it 1/2" you also should go back 1/2". That will keep the geometry the same.
Yes, right now I have the front arms in the upper holes, and will drop them both the same. Good info on the backwards as well. This is a custom sled with a rear section of a tunnel from an m8 so clearance is not the same, I have a tip up in my tunnel between the drivers and the drop brackets that's what's getting me into trouble.
So your rear mount is behind the tip up of the tunnel. So you need longer drop brackets because the bracket is now being mounted on the part of the tunnel that is rising vertically.
So is the distance of the rail tips to the front arm mount on the racer rails the same distance As the M skid?
