Adding pull start
cubby
499
So I have a 2012 summit 800 etec and came across a rewind starter part number 420892618 and am wondering if all I need to do is pull my cover off and install this rewinder to have pull start as a backup
F
153
Minnesota
u also need the rewind cup/bolts for the flywheel.
Cutting the side panel is a bit tricky as it does not have the formed in recess the factory pull start panels have.
Srhone
42
17
If it is only a backup why cut the panel? I would just open it and pull, then close it back up. Just sayin...
cubby
499
Yes it is only for backup, so I was hoping I can just leave the handle in there some where. but have not looked to see if there is room. Just put in a new battery on Sunday because sure enough it was dead. I got 5 years out of that factory battery always on a tender but I thought that was good.
Srhone
42
17
There will be plenty of room, not a concern. My cousin did it on his 16 after the e start was acting up.
