2018 clutches on 2015 M8000?
F_ast
973
361
Ontario
Anyone know if the 18 team clutches will directly bolt onto 2015 crank and jackshaft?
Wondering if they are direct replacement?
boondocker97
4,080
2,802
Billings MT
Primary is. Secondary is not. Would require changing the jackshaft, or jus use a tied secondary on your jackshaft.
F_ast
973
361
Ontario
Im the OP.
I have a 2018 Highcountry. So am i able to run both team primary and secondary from an 18 on my 15 without any offset issues?
sno*jet
2,829
1,299
is there a big benefit to going to the team clutches I have a 2014 162
I think its the primary that lasts longer, less maintenance. I would run a 17 primary and leave the cat secondary if I had a pre-16 sled. 17s are solid, couple choices on belts, lots less $$. no annoying slippage in reverse like the 18+ setup.
boondocker97
4,080
2,802
Billings MT
Im the OP.
The jackshaft/clutch interface is completely different on a 2015 than it is on a 2018. So the secondary will not even bolt up. If you change the jackshaft out too, then you can put the 2018 clutches on the 2015.
I think there are a few guys who have claimed to have gotten their deflection set tight enough with the older style secondary to be able to run the 2018 primary with it. Whether it was enough to get absolutely tight and take full advantage of the 2018 primary, I don't know. My primary was needing a rebuild and the secondary was starting to get worn and bind, so I replaced it with a Tied secondary setup and mated it to a 2018 primary on my 2014. That I know works.
boondocker97
4,080
2,802
Billings MT
Better durability on the primary. Performance wise the 2018+ primary has smoother engagement and lower take-off gear since the belt is run tight. Top end performance I'd give the edge to the older setups. Just felt like the secondary shifted out further. Unless your clutches are getting worn out and due for rebuild/replacement I wouldn't make it a priority to change them over. For the cost the difference doesn't carry a huge wow factor IMO.
Cat00
85
X2 couldn't agree more
Cat00
85
I was lucky to get a couple hundred miles out of a belt with the stock clutches.
I'm running a machined cat secondary from tom at mountain valley motorsports have 400-500 miles on a belt still looks new
boondocker97
4,080
2,802
Billings MT
On the stock 2014 clutches I got 1000 miles on the original belt with the big bore since day one before I figured I should change it. I grenaded a 084 with 125 miles on it going too fast for 10 miles down a trail. Pulled apart (literally broke in one spot) an early gates carbon belt in 150 miles, and wore out another in 300 miles. They just didn't last. Kept going back to that original 084 and got 1300+ total on it. It's got some cracks in it now and wouldn't last another trip.
