B
What turbo are you running and what do you like/dislike about it?
On your 3071 is it a drop in compressor wheel or is it bigger can you give a little more info on it, do you also have the 4" Compressor inlet? I'm currently running 2860 with water/air intercooler with the standard .86 waste gated housing at 10-12psi. I have a 2871 i'm going to try but I have a feeling I'm not going to like the loss of low end. Just curious about maybe trying a 3071 also.I have a 09 m8 with a 3071 .63 on the exhaust side and a hta billit on the intake side no inner cooler I run a straight 3 degree advance at 9/10 psi its very responsive. I have rode others with smaller turbos and was not very impressed but it could have been there whole setup and not just the turbo.I oil it with the stock pump and fuel is the stock pump as well with the BD fuel card its super simple setup and it works
Thanks
Sent from my HTC One M9 using Tapatalk
Thanks, do most people run the smaller compressor housing? I have the same weights just a straight 36 helix though probably need to get a new one.
