Edit: File size reduced so could load to Garmin GPS. I still have the larger file if anyone wants it. This file still seems to have better resolution than an older version posted in the forum since the state has provided a larger PDF map base file.
Try the attached Snowies file. I have created google earth overlay file.
NOTE: Snowest does not allow .kmz files to be attached to threads, so you will need to change the name of the attachment as described below:
1. Download the "2016 Snowies.pdf" file to your computer
2. Rename the file to "2016 Snowies.kmz"
3. Open the file using Google Earth
4. Make sure that you have your sidebar turned on (View -> Sidebar)
5. You should see the 2016 Snowies map listed under "My Places". Right click on it and select "Properties" - now you can adjust the tranparency and move the map around if you want to try to get things to line up better than I did.
6. If you have a newer Garmin GPS unit that allows you to upload custom maps follow the directions at this website starting with step #5 (I have done steps 1-4 for you)
http://www.garmin.com/us/products/onthetrail/custommaps#fragment-2
