B
just took my sled out today and it blew up within the first 2 mins i recently just took the carbs off and put v force reeds in and jetted it leaner from 340 main jets to 360 mains and the changed the needle setting down to 2 from 3 setting and when i just took off the carbs tonight i looked at the oil line that was going from the oil resevoir to the oil pump it was pinched.
im wondering if i leaned the sled out too much with that jet and needle setting or if it was the oil line? does it make sensce to lean the sled when putting v force reeds on?
oil pump cable is also sticking to wide open...anyway to fix this problem?
