18 Clutch on 16/17???
jakey-boy
1,447
787
Idaho Falls
instagram.com
Who's done it? Bolt on replacement?
Update found an old thread from Racin Station. Looks like it needs the primary clutch/new belt, an alignment bar and shim kit. Should be pretty easy!
Cat00
85
It will bolt right on but you might have to shim your secondary to get the alignment right
Allseasons
238
130
Rocky Mtn House AB
18 clutch on 16. I got to test and tune yesterday. engagement is smooth, and the deflection bolt noise is gone. Pricey but well worth it imho. Early snow, but nice getting out already
jakey-boy
1,447
787
Idaho Falls
instagram.com
Did you leave the exact same clutching in? Same springs weights etc? For your secondary you just took out the deflection bolt and aligned it correct?
Allseasons
238
130
Rocky Mtn House AB
Yes really easy. I transferred over spring and weights, I added weight since I was still over revving, took out deflection bolt, aligned, and have to say I'm really pleased. With the 18 clutch and added weight, my engagement dropped from 4800 to 41-4200. Super happy
Chewy22
1,996
1,371
Montana
I’m going to give the 18 primary a try on my 16 as well. See how it goes.
sno*jet
2,829
1,299
need newer belt too right. and belt rides higher in secondary for lower geared take offs? i would hope so with the ol zuke..
CRJPilot
162
98
Farmington, MN
I would assume the new 0627-111 belt would be needed as it is over 1" longer in length and .06 wider than a 084.
2018 belt #0627-111 is 48.582" (+/-.180") long and 1.508" wide.
2017 older #0627-084 is 47.520" (+/-.180") long and 1.448" wide
Can anyone else confirm the need for this new belt on the Zuke? Is the center to center distance longer on the new ctec2 vs. zuke?? Maybe new belt only required on 18s with ctec2?
Old & slow
728
393
Alberta
You need the 111 or equivilant
boondocker97
4,081
2,802
Billings MT
Are weights interchangeable between the 2016/17 and the 2018 clutch?
I'd be doing this on my '14 right away if I didn't have to get new weights and spring and start my tuning over again. :face-icon-small-dis
CB.8
Skidoo hill crew
450
Colfax, WA
My 16 engages between 3700-3800 with sock clutches. Buttery smooth except for the dreaded secondary chatter.
