Here are the symptoms (2011 800 Etec):
The problem started on the first ride this year. When the motor is already warm, it will begin to sputter and loose rpm, then a few seconds later it will begin to scroll "warm up" across the speedo. While in this "warm up" mode it will not allow rpm's above about 5800-6000. Shuting down and restarting doesn't seem to reset anything.
I took it to the dealer this week, they put it on Budds, they said they couldn't find anything so they contacted BRP, BRP blamed it on the aftermarket pipe and can (SLP). They said they wouldn't continue to diagnose it until the original pipe and can were installed. I put the factory pipe/can back on today and had to be towed back to the truck.
Some new symptoms developed today. It would sputter to a stop and die, I could restart it, but it would only idle at about 6-800rpm, not fast enough for even the speedo and instruments to funtion. If you even breath on the throttle it will die. Check engine light come on, and stayed on when it began doing this.
My quesses, in order of probablity.
ECM Failure
Stator
Fuel injector
Electrical short
OK motorheads, tell me what is wrong?
ECM Failure
Stator
Fuel injector
Electrical short
