boost-it coming soon to a doo near you
B
BigFish BC
3,348
1,139
kitimat b.c
boost-it coming soon to a doo near you,small vid added
all new boost-it etec doo kit, cant order kits yet as they need to finish testing, but thought i would post this up to show whats coming.there mite be a few kits available this year but will depend on testing.
More etech sneak Peak. Full Barometric pressure compensation, intake air temp adjustment, full plug and play, dual exit muffler, water to air heat exchanger in the tunnel, divorced water to air intercooler.
small vid of it at shop,will have it in mountains testing soon.
https://www.youtube.com/watch?v=OuQSxzzmImE
67309_834855259900012_6686443134493737586_n.jpg 10406369_834855189900019_258534491498775668_n.jpg 10407739_834855109900027_5460700863167466641_n.jpg 1381389_837009546351250_6059445626803871966_n.jpg 1459846_837009526351252_7652958838767812911_n.jpg 9442_837009566351248_5183309862660262175_n.jpg
Rotax_Kid
734
274
Regina, SK
Looks like the same absolutely terrible fit and finish Neil is known for!! hehe...looks very purdddyyyy
Shred4Ever
129
57
That is a very nice setup! Well thought out placement for W2A... I'm certain this kit will make a few others a wee bit nervous! Looks like a quality fit & finish!
summitboy
851
I just ran into Neil on a socked in day at the back of Boulder. He was sporting the new XM 174 with his Boost It XM turbo. I have to say it sure ran well. First XM turbo kit i have seen that actually runs awesome. No burbles and clean all the way through.
I watched him do a nice little poke at 5psi. My stocker 163 was no match ha ha, although i did try a couple times.
The kit sure is pretty looking under the hood, no screwin around !
B
BigFish BC
3,348
1,139
kitimat b.c
new video of some testing this is at 4-5lbs boost.
watch
https://www.youtube.com/watch?v=NdpaoBDoukk
B
BigFish BC
3,348
1,139
kitimat b.c
so price on the new doo kit is 6700$ can,they built 14 kits & only 7 left if you want one,give the shop a call.they come with,Garrett turbo, water to air intercooler, Turbosmart BOV and boost control, primary and secondary clutching, stainless muffler with belly and tunnel dump, intake air temp and barometric pressure compensation.
F
Nov 27, 2007
2,495
712
medicine hat
What weight does this kit add to you sled over the parts you remove... Aero is break even, impulse is plus 6, tss is plus 20 with w/a
How many hp is the turbo good for
F
Nov 27, 2007
2,495
712
medicine hat
You can buy aero with or without the intercooler, and their intercooler is a snow/air cooler so no weight gain and no coolant, pumps, or separate heat exchanger..very clean
B
BigFish BC
3,348
1,139
kitimat b.c
iam not 100% on weight but i would say 10lbs at most gain,after many years of running air to air coolers & now using water to air i would not go back.the water to air weight penalty is worth it for how much more consistent they run with water to air.as for hp that depends on your choice of turbo they have a bunch of diff options.
F
Nov 27, 2007
2,495
712
medicine hat
they built a airbox that you need to cut out a 4 inch by 10 inch roughly strip from the top of your tunnel.. then they have their charge air come threw bottom of airbox where it is cooled by the snow touching the box before going into throttle bodys
their first kits offered a non intercooled airbox, and now you have the choice, my charge temps have been ok with out being intercooled, but maybe someday
Not getting it. It not water to air so it's air to air. How do u do snow to air.
