Upgrade to Premium
Polaris: TURBO Turbo discussion for Polaris aftermarket turbo sleds
Reply
  #1
Old 12-26-2018, 11:14 AM
Dzurowsk Dzurowsk is offline
Currently: Not set.
Basic Member
Dzurowsk is an unknown quantity at this point
Default Silber axys 800 rmk install sidepanel interference
Hello, I am new to the forum and figured I would seek everybody's advice on here. I have just installed a Silber turbo on my 2016 axys 800 rmk and everything went well accept for the fact the turbo actuator contacts the side panel when installed. Does anybody else have this issue and if so has it caused any problems? I have tried to move it over but does not seem possible without any heavy modifications. Thanks
Rate this post: Yes | No
  #2
Old 12-26-2018, 11:59 AM
WAsledder WAsledder is offline
Currently: Not set.
WAsledder has a reputation beyond reputeWAsledder has a reputation beyond reputeWAsledder has a reputation beyond reputeWAsledder has a reputation beyond reputeWAsledder has a reputation beyond reputeWAsledder has a reputation beyond reputeWAsledder has a reputation beyond reputeWAsledder has a reputation beyond reputeWAsledder has a reputation beyond reputeWAsledder has a reputation beyond reputeWAsledder has a reputation beyond repute
Default
My silber is really close to touching the side panel and I noticed when I rolled the sled over or the sled was laying on its side panel it would melt the panel. I ended up heat taping the side panel and haven't had any issues since.
  #3
Old 12-26-2018, 02:03 PM
Boston Racing's Avatar
Boston Racing Boston Racing is offline
Currently: Living the Dream.....
Boston Racing has a reputation beyond reputeBoston Racing has a reputation beyond reputeBoston Racing has a reputation beyond reputeBoston Racing has a reputation beyond reputeBoston Racing has a reputation beyond reputeBoston Racing has a reputation beyond reputeBoston Racing has a reputation beyond reputeBoston Racing has a reputation beyond reputeBoston Racing has a reputation beyond reputeBoston Racing has a reputation beyond reputeBoston Racing has a reputation beyond repute
Default
There is a nipple on some of the side panels that contacts the blow off valve housing. Grab a pair of diagonal cutters and remove it. Then you will be good to go.
The Following User Says Thank You to Boston Racing For This Useful Post:
WAsledder (12-26-2018)
  #4
Old 03-08-2019, 07:28 AM
braapin braapin is offline
Currently: Not set.
braapin has a reputation beyond reputebraapin has a reputation beyond reputebraapin has a reputation beyond reputebraapin has a reputation beyond reputebraapin has a reputation beyond reputebraapin has a reputation beyond reputebraapin has a reputation beyond reputebraapin has a reputation beyond reputebraapin has a reputation beyond reputebraapin has a reputation beyond reputebraapin has a reputation beyond repute
Default
I have interference with my side panel as well after clipping off those tabs. Any ideas ?pictures of where it’s touching...
  #5
Old 03-08-2019, 07:49 AM
willjogervais willjogervais is offline
Currently: Not set.
willjogervais has a reputation beyond reputewilljogervais has a reputation beyond reputewilljogervais has a reputation beyond reputewilljogervais has a reputation beyond reputewilljogervais has a reputation beyond reputewilljogervais has a reputation beyond reputewilljogervais has a reputation beyond reputewilljogervais has a reputation beyond reputewilljogervais has a reputation beyond reputewilljogervais has a reputation beyond reputewilljogervais has a reputation beyond repute
Default
I had the same problem on my 16 and now on my 19. Heat tape it and run it. No problems for me
  #6
Old 03-08-2019, 08:01 AM
Currently: Not set.
Default
Looks like it’s actually from damage from previous owner of sled - he hit something and it pooched side panel in a little bit right at those little tits that I clipped off. Guessing that’s the deal. Bought some heavy heat tape. Or maybe I can trim side panel a little? Guessing there’s no moving that valve ?
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Avalanche/radio interference axys Thread Starter — Thurel Forum — Polaris: AXYS Replies — 33 Last Post — 03-25-2018 01:53 PM
Thread — Silber turbo install? 2016 Axys Thread Starter — rockin rmk Forum — Polaris: TURBO Replies — 7 Last Post — 02-19-2018 08:12 PM
Thread — Installing silber turbo on 16 axys what should I do/check before install? Thread Starter — Prormk99 Forum — Polaris: TURBO Replies — 7 Last Post — 10-17-2016 12:11 PM
Thread — 16 polaris Axys rmk 800 Silber turbo build Thread Starter — purepolaris600 Forum — Polaris: TURBO Replies — 7 Last Post — 03-27-2016 12:51 PM
Thread — AXYS SILBER TURBO INSTALL...in under 48 minutes Thread Starter — tudizzle Forum — Polaris: TURBO Replies — 14 Last Post — 02-22-2016 08:51 PM
no new posts
