B
Is it possible to simply put a 3" track on a belt-drive Axys that comes with the 2.6"?
Or do you have to change drivers?
Thanks
Thanks
Thanks
2.6 track is a 2.86 drive pitch. The 3.0 track is a 3.0 drive pitch. The "correct" answer is you have to change drivers. However.... I know guys that have done this without changing drivers and have reported no issues
I'm pretty sure there is a gear reduction (12 or 13% is advertised) that goes with the 3" and that is also a part of the consideration. If there was a readily avail belt drive pulley set to make the right gearing, those with 3" lugs might have a belt drive from the factory......
8 tooth, 3"-pitch drivers will not give you adequate lug tip clearance with a 3"-lug track however.
Thanks for replies everyone. So, the 3" lug track will fit, but still need to change drivers to accommodate the different pitch. Looks like Avid makes centre drive 3" pitch 7 tooth drivers that will work.
