E
Evolution Powersports has developed an upgrade kit for the OEM MPI Viper Turbo Kits.
Our kit is designed to upgrade the boost from stock levels for the factory kit to 9 lbs (true) of boost at any elevation. The kit includes a set of (3) 550cc direct replacement, plug and play fuel injectors, a boost T for adjusting boost pressure (electronic boost control is optional) and an ECU Reflash which changes the timing to a more boost friendly curve, raises the rev limit to 9800 and corrects the fueling for the additional boost. This kit is 91 Octane safe.
The basic kit with will have a retail price of $1199.00 and is a dyno verified 35 horsepower gain over the OEM kit. Also, this kit is EXTREMELY easy to install - it can be done in less than 30 minutes whereas fuel pump upgrades are very difficult and time consuming on the Viper. The larger injectors are capable of supplying enough fuel for 260+ hp with the stock fuel pump and regulator.
The kit will be easily upgrade able as we plan to develop a Stage 2 with 250 horsepower for next season which will consist of an air to air intercooler and more boost.
Eric at the Racin Station and a few other select dealers will be testing the kit within a week or so.
Dynos and videos of the dyno and field testing will be posted soon.
