Thanks, I was planning on going but had a last minute deal that I had to see through pop up...:face-icon-small-sad just one of those things, and buisness comes first.
Damn 2XM3, I was really hoping on meeting up with you too since we were over in your neck of the woods. I was really hoping on throwing a leg over your sled for comparison purposes. I wanna check out this clutching setup that I'm probably going to be switching too this summer anyways.
that is absolutely wrong you are forgeting about ignition.same given boost,AFR and one has control of timing and the other not, the timing controlled sled will make approxi. 10%-15% more if not greater. when boosted the dwell cycle(how long you are charging your capacitor for a longer spark duration and intensity) is another factor that will affect performance (hp).....all stuff a standalone take under control.
This is true. Obviously 2XM3 was thinking timing being the same.
Matt,just to correct you I was on 6.2 psi at that time we raced,went to 9 psi in the late afternoon. Pulled 84.2 track speed on 9 psi . Only pulling around 73 when I was 6 psi in those snow conditions. That peak track robs major power in that wet stuff.
Ok, I came buy the 6.2 thing. But,why did you spend so much time on your laptop prior to the race then? You told the guys standing around that you were turning up the boost and uping the rev limiter(because your weights were too light for the higher boost you wanted to run) What changed your mind?
Also, I wanna know what you track speeds are on a DEEP & STEEP fresh snow hill, NOT a hard packed hill spring snow hill. Even those vids in Cooke don't look like that soft of snow. When your ground speed and track speed are very close thats not a good time to check track speeds. I check track speeds when I'm wot, pulling up a deep, steep fresh hill and my ground speed is much lower than my track speed. Hell, I can put much sled up on a track stand and get high track speeds, once again it means nothing. After you started making these claims about mph and whatnot again at the event, I cleared out my max mph recall and checked it immediately after the drag race. Guess what? At the 9psi & broken clutch spring that I had I still had a 76mph track speed.
Personally, I expected with Shane running 7psi, you running 6psi & me at 9psi to be very close & it was. I don't think anyone should have any shame in this, it seems pretty realistic. (However I do wish that my primary spring wasn't broken,LOL) I would expect the advanced timing, water to air intercooler & Vipec ecu control to make up a 2-3psi difference.
