T
I finished installing my kit tonight. I have issues though. I haven't gotten a chance to call Silber yet.
My idle is really high. It idles at around 3000rpm's. Actually it surges up and down between 2500 & 3000(the a/f's follow the rpm's, the higher the rpm the leaner it shows, at 3000rpm its at about 15.5afr) Every once in a while when I start it up it will idle normal for awhile, then when I give it some gas it revs up and idles high. I have been over all the vac hose connections on the billet boot a couple times and that all looks good. I don't know whats going on. Another thing I did try: I unhooked the control box at the injector harness and hooked the injector harness back together stock. When I fire it up this way the sled still idles high, about 2500rpm's, but its rock solid there , no surging like before. I don't know whats up with that.
Is it possible that my idle speed just needs to be adjusted? That seems strange. I didn't adjust my throttle at all in the process of the install. I did unhook the cable, but I have it back on correctly. I checked that a couple times. I also checked my throttle free play, that looks the same as before the install as well.
Has anyone experienced or heard of any issues like this? Any other ideas? Any help is appreciated.
