1
08’ Yamaha Turbo Nytro with reverse
will be in Revey this week.
This is a clean well put together T-Nytro That ran its first 500 miles non-boosted. It is a great running gas and go sled usually ran t 10 to 12 lb boost. Completely ready to ride minus gas it weighs in at 580 lb (digital scale verified). Drive shaft bearings and chain case bearings and seals replaced when track was installed as a safeguard. Buy this ready to ride T-Nytro and save time and money. Keep up with your buddies for half the price.
• Powderlites stage 2 with head shim and timing(14 lb on pump gas 280+ HP)
• Track 162”x15”x2.5” (Camoplast M#9943M)
• Avid drivers
• Fast M-10 with live rear axle front Assault air
shock, rear Fox coil over with Fastrax TI springs and bilet adjuster.
• Zbroz Exit XO front shocks
• Tunnel VE(VanAmburg) 162” extension and
bumper with 2010 Better Boards
• Clutch Supper tips and Shockwave
• Clear Trail Tank
• Simmons Gen 2 skies
• Pingel tether
• RSI grips and hand warmers
• Snobunje left hand throttle
• Slide kicks ice scratchers
• Skins wind shield bag
• Mountain Addiction Gas cans
• Sled Shed Seat 2.5” topper and cover
• Pelican Case
• Light weight battery
• Custom LRS Throttle Perch
• Custom LRS Steering forward relocate
• 2 spare belts and Custom LRS Belt holder
• Cover
• Rapid Bike soft ware and cable
$16,000 US funds. Would consider part trade for a Ski-Doo XP
Sorry about the new post but I was not able to edit the old one.
I will be in Revey From the 16th to 20th with the sled.
The TI spring was added after some of the pictures it is aprox 6 lbs savings. and works way better.
• Avid drivers
• Clear Trail Tank
• Pingel tether
• Pelican Case
• Cover
