J
Long story short... down on RPMs, obvious things have been done (clutch, belts, plugs, EV valves, tps, etc..) and tackled to no improvement. Dealer mention next step would be to do a leak down test and scope the cylinder...
I have a sled mechanic where I work and was talking to him and we decided to check a couple quick things...
Ok, so a quality pro gauge used, I did a dry compression test and got about expected results for my elevation. Then added a bit of oil to each cyclinder and performed same test. One cylinder had an ever so slight increase (1-2psi), the other cylinder increased by 34psi!
From my reading on the internet a very slight increase is "normal" as it is the change in volume due to the oil in cylinder, where as a large increase tells there is a seal problem somewhere. Correct?
Tomorrow we are doing a proper leakdown test to try and find the culprit, but if I was a betting man I'm guessing ring seal...
I'm not an expert so just trying to get educated on things as we go so I have the knowledge for future reference.
