Incentive to order in the spring. Is why you have your top of the line product with the goodies.
Dave - Is there any difference with the spindles besides being lighter? Doo they affect the handling at all?
Curious since they are available in the accessory catalog. Thanks.
Yes they are more stood up, more aggressive stance, and yes you can add everything to make a 17-18-19 like an expert except the tunnel and the boards.
It's too bad that BRP didn't make it so that 17-18-19 owners of the X package can't simply add the forward extruded section of the running boards (the part that is stamped sheet metal on the older models).
It looks like the new running boards have the same "seam" as the old boards did between the extruded and stamped portion. How hard would it be to make the forward extruded section retrofitable?
retrofitable does not rhyme with protifable...wait, it does.It's too bad that BRP didn't make it so that 17-18-19 owners of the X package can't simply add the forward extruded section of the running boards (the part that is stamped sheet metal on the older models).
