I see lots on how to build the tester and how to set the throtle bodies, but how do you set the tester up if you don't have the proper connector? And is it better to test the sensor or go right from the ecu?
I used the alligator clips to connect and tested right @ the sensor
So the TPS numbers on the sticky video, they work for an 06 Switchback?
(.705-.715 and 9.30v)
