121.0lbs / 54.9kg For ARO3
117.0lbs / 53.1kg For ARO129
4lbs extra.. all in the paddles as extra moving mass.
Plus added traction.... all that needs power to drive it.
So... It will definitely have an effect.. It will also be rider and snow condition dependent, but there will definitely be times the ARO129 track out performs the ARO3.
The positive or negative balance about which one is better time will tell if its bigger is better spin from the marketing department or a technical improvement from the product development department.
If you think the back of the track collapsing and ski rising up is good for the backcountry and climbing buy a riot!... just make sure you get the LE version as it allows you quickly adjust the rear suspension to stop this. (Last I checked std version does not)
FYI you can achieve a somewhat similar effect on any kit by gimping the rear shock and softening it up, positive is the RIOT LE is the only system you can do this quickly and easily with out tools, so you can show off for a bit and set it back to normal and ride the rest of the day and not get left behind.
