Water to air intercooler with a garret setup
Jan 25, 2010
19
doesn't look like my link worked, but the intercooler i was looking at is the type 13 on www.frozenboost.com
i have had a water to Air on my sled last 2 year. put 4 on hill climbers at jackson last year. found more power But sizing is more important then you might think to big more lag to small = hot air for the intake. The right size and the right water piping is the key or you will be unhappy. Happy to help if needed.
KMOD
463
Firth
kmodsnowmobileparts.com
Sparkey
Were the water to air coolers you done, self contained?,
their own cooling exchanger or tied into the engine coolant?
And how big of motors?
I'm a firm believer that cooler intakes make more power but I hate the idea of extra pumps and electrical draw.
Thanks Kevin
Jan 25, 2010
19
Sparkey
Thanks Kevin
Did you see the one brad has on his 1200 ? he uses a separate pump and cooler he runs a lot more engine heat kind of like your 1200 beast 800 can be done different with great results. your hole shot could suffer and ground speed should be on the top end. that little 800 on your tail last spring had a water to air cooler.
