R
Took my sled out yesterday for an early ride and used approx. 3.5 gal in 23 miles (37 km) of just trail riding within 2 hours. Seems a little excessive. Any ideas why?
You probably use the PURE TRADGIC box would advice you to take it off ASAP, and buy a new systemTook my sled out yesterday for an early ride and used approx. 3.5 gal in 23 miles (37 km) of just trail riding within 2 hours. Seems a little excessive. Any ideas why?
42 is the right f.pressure. you should buy Boost it to fuel your sled and PC ignition module, to get the most power out of your sled.I'm running the Pure Logic (Tragic) fuel controller. Pump gas at around 12 boost. Seems to be running a bit rough bottom end and great top end. What fuel pressure should I be running. I read 42 psi. Going to call Alpine today. Might have to install the trail tank if I can't get better fuel consumption. Can only carry so much fuel up the mountain. No leaks.
Tod was their best builder, and he told me 42psi are you running big inj. and high fuelp. the pure logic just breaks. i think i used 5 in 2-3 months. theiy will break if you just make a to loud http://www.youtube.com/watch?v=FB7rKMcNnakCalled Alpine. Thinks it is most likely fuel controller settings. Boost it might be the best option. Fuel pressure should be 52 to 53 psi. Quoted air-fuel ranges for idle, cruising and under load. Might try one more time before I think about switching controllers. Mountain Mod seat and trail tank is around $500 to $600. Going to get that for sure.
