I'm running an older Silber kit on my 2015 pro. Duel injectors, Dobeck controller and oil pump.
as far as I can tell the code is for the BAP sensor. (low Voltage)
Is there a way to fix this issue? bad sensor? Iv heard of people running an accessory battery to correct unstable voltages. Which could cause my code. How could I wire in a battery to be charged, and active with the key so the pump doesn't run all the time.
