thinking some are just loaded up.id break mine in like a race car and den see how it idles..LOL
Still experiencing the TPS/low idle issue on my sled after dealer already adjusted TPS. Was told to "run some gas through it" to see if that helps... Yes, the sled did seem to be swimming in oil and very loaded for the first 10-20 miles, but now have just over 100 miles on it, two tanks of gas through it, and it still will not hold an idle any better than the day I bought it, especially from a cold start. Sled chugs and dies out as soon as it hits about 75 degrees every time I start it. Stya on the throttle just to warm it up and try 5 times to get it into reverse before riding. And it will only hold 1400 rpm idle after fully warmed up. So it's going back to the dealer later this week for more fiddling with the TPS... Can't understand why some guys are having such success after dealer adjusts TPS the first time and others are not.. sure hope they get it right this time. Wish I had the tools and time to do it myself. Winter is passing by each day, another big storm coming this weekend, and my new axys still does not idle and will be stuck at the dealer anyway
Im almost willing to bet that they didn't do it right. Did they adjust the base idle voltage or just stick DW on the sled and adjust the idle that way?
^^^ this.
All dealers are not equal.
Having a similar issue did you ever find the solution to this?Mine is pretty low too. At home in Wisconsin at 900 feet it idled great between 1700-1800. On my way back from the snowy mountain range between 9000-11000 feet it did not like to idle. There were times after pulling the rope it wasn't idling high enough to turn the gauge/lights on right away. It idled 1400-1550 consistently. I changed plugs on day 2 without any change.
