What Reeds?
Cerialsledder
SnoWest Badge Maker
1,873
1,128
Sault Ste Marie, MI
I have the same setup as you do with the slp heads and port job and am running the stock reeds and cages. I believe there was a post somewhere about running the vforce 3 reeds. Have to do a little digging to see what you can find.
K
Oct 29, 2014
42
1
8
Does it run well? I was concerned with the re-mapping of the ecu it might throw something off to run any reed set up other than what SLP recomends.
guidoxpress
5,105
1,506
Wasilla, AK from MT
ONLY a run stock reeds. Trust me they are the only ones that last..others chip eventually. Stock will out perform any aftermarket reed pedals
rmkboxer
323
83
46
Bonney lake WA
the new v force reeds work very well, I have put them on mine and it runs way more efficient. I'm sure slp has a different map if you use v force reeds or not.
