Upgrade to Premium
Arctic Cat: M Series 2005-2011, all models in the M-series chassis
Reply
  #1
Old 12-27-2018, 06:49 PM
adam5187's Avatar
adam5187 adam5187 is offline
Currently: looking forward to enjoying thebully dog upgrade.
adam5187 has a reputation beyond reputeadam5187 has a reputation beyond reputeadam5187 has a reputation beyond reputeadam5187 has a reputation beyond reputeadam5187 has a reputation beyond reputeadam5187 has a reputation beyond reputeadam5187 has a reputation beyond reputeadam5187 has a reputation beyond reputeadam5187 has a reputation beyond reputeadam5187 has a reputation beyond reputeadam5187 has a reputation beyond repute
Default 2007 crossfire 1000 pto side piston failure.
Last run last year 1800 miles on sled stock except can. Lost pto side piston. Tore down and rebuilt top end. Broke in with 2 tanks of gas. Riding it yesterday across the lake and at pushed it and at 90mph lost pto side piston again after about 4 seconds wot. Pulled engine down and pto side has 4 corner scuffing like a cold sieze. Not lean beutiful burn and mag side looks perfect. Not sure where to go was wondering if anyone has ran into thermostat problems that could cause it to not build enough heat in the cylinder. New to arctic cat so if anyone has any info i would appreciate it. Thanks
Rate this post: Yes | No
  #2
Old 12-27-2018, 06:50 PM
adam5187's Avatar
Default
Not sure how to get the pictures up it is telling me my pic are to high resolution but cant get my camera low enough
  #3
Old 12-27-2018, 09:29 PM
kiliki kiliki is offline
Currently: Not set.
kiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond repute
Garage
Default
pull the oil pump seen a few when the owner changed oil and it jellied in the pump
  #4
Old 03-01-2019, 02:48 PM
adam5187's Avatar
Default
I changed the thermostat out and re did top end. Been out 4 rides now and really worked it and have not had any issues. So as weird as it seems the thermostat change so far has seemed to address the issue.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — bearing failure, crank, pto side, 2015 pro Thread Starter — MrIQR Forum — Polaris: Pro-Ride Replies — 8 Last Post — 02-01-2017 05:18 PM
Thread — 2007 summit 600 ho sdi pto piston scuffing Thread Starter — foremost Forum — Ski-Doo Replies — 0 Last Post — 03-05-2012 05:42 AM
Thread — 08 600 cfi pto side failure Thread Starter — ak600rmk Forum — Polaris: IQ Replies — 1 Last Post — 01-17-2012 01:54 AM
Thread — M7 turbo enging failure pto side Thread Starter — Snostruck Forum — Arctic Cat: TURBO Replies — 25 Last Post — 11-28-2009 11:52 PM
Thread — 99 mxz burning down the pto side piston. Thread Starter — Fr8tdog Forum — Ski-Doo: S-2000 and older Replies — 4 Last Post — 10-28-2009 06:16 PM
no new posts
