Upgrade to Premium
Ski-Doo: REV Gen 4 For the 2017 and newer REV Gen 4 Sleds
Reply
  #1
Old 04-17-2018, 10:47 PM
donbrown's Avatar
donbrown donbrown is online now
Currently: Let it snow !!!
donbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond repute
Default Optimal RPM
Called several shops about clutching.
Most say 7950 to 8000
A couple say 7900 plus minus 50.
What do you say?
__________________
www.CNSA.NET lifetime member
Rate this post: Yes | No
  #2
Old 04-17-2018, 10:57 PM
Clutched Films's Avatar
Clutched Films Clutched Films is offline
Currently: Not set.
Clutched Films has a reputation beyond reputeClutched Films has a reputation beyond reputeClutched Films has a reputation beyond reputeClutched Films has a reputation beyond reputeClutched Films has a reputation beyond reputeClutched Films has a reputation beyond reputeClutched Films has a reputation beyond reputeClutched Films has a reputation beyond reputeClutched Films has a reputation beyond reputeClutched Films has a reputation beyond reputeClutched Films has a reputation beyond repute
Default Rpm
7971 rpm on the dot no more no less!
3 out of 3 members found this post helpful. Rate this post: Yes | No
The Following 2 Users Say Thank You to Clutched Films For This Useful Post:
Dartos (06-06-2018), donbrown (04-18-2018)
  #3
Old 04-17-2018, 11:19 PM
ak ak is online now
Currently: Nothing
ak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond repute
Default
Here. RPM, horsepower, torque stock 850.
2 out of 2 members found this post helpful. Rate this post: Yes | No
The Following 8 Users Say Thank You to ak For This Useful Post:
Adam12 (05-07-2018), Blk88GT (04-18-2018), donbrown (04-18-2018), MountainTrashCat (04-18-2018), rab (09-09-2018), sledhead_24_7 (04-18-2018), TheOnlyBFC (04-18-2018), turbo800 (04-18-2018)
  #4
Old 04-18-2018, 08:41 AM
donbrown's Avatar
Default
Quote:
Thank you for the precise concise number. Will the accuracy of the RPM meter allow such accuracy?
Called 4 shops yesterday.
Was interesting the ones I've done business for decades say leave it stock and use the existing clickers to get 7900. Only get a clutch kit if sled was modified.
Maybe change the spring and or helix to lessen the trenching by engaging at lower RPMS also helps backshift.
New shops I called said to get a kit and strive for 8000 RPM
Not uncommon to overrev peak to hit 8100 to 8300 and system retard starts at 8800 RPM?
Unfortunately a days drive away from snow with no time off really test the sleds with no miles
__________________
  #5
Old 04-18-2018, 08:43 AM
donbrown's Avatar
Default
Quote:
Thank you.
__________________
  #6
Old 04-18-2018, 09:21 AM
winter brew's Avatar
winter brew winter brew is online now
Currently: Not set.
winter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond repute
Default
I've always shot for getting a little overrev on the flats (100-150 over peak) and let it work on the hills at 79-8000. No need to be any more precise than that, you have a tachometer that is not perfect, terrain that varies and engine output that varies with temp and altitude. That's the nice thing about a big twin, they have a fairly broad range of usable power.
4 out of 4 members found this post helpful. Rate this post: Yes | No
The Following 7 Users Say Thank You to winter brew For This Useful Post:
donbrown (04-20-2018), fynnigan (04-18-2018), LPIdaho (05-08-2018), Matte Murder (05-08-2018), MountainTrashCat (04-18-2018), PaulAnd (04-18-2018), sledhead_24_7 (04-18-2018)
  #7
Old 04-18-2018, 06:44 PM
MountainTrashCat's Avatar
MountainTrashCat MountainTrashCat is offline
Currently: Official Doo Belt Tester
First SnoWest Premium Member
MountainTrashCat has a reputation beyond reputeMountainTrashCat has a reputation beyond reputeMountainTrashCat has a reputation beyond reputeMountainTrashCat has a reputation beyond reputeMountainTrashCat has a reputation beyond reputeMountainTrashCat has a reputation beyond reputeMountainTrashCat has a reputation beyond reputeMountainTrashCat has a reputation beyond reputeMountainTrashCat has a reputation beyond reputeMountainTrashCat has a reputation beyond reputeMountainTrashCat has a reputation beyond repute
Garage
Default
That’s a pretty big fat juicy target from 7600 to 8000
__________________
http://www.avalanche.ca/sled
The Following 2 Users Say Thank You to MountainTrashCat For This Useful Post:
donbrown (04-20-2018), sledhead_24_7 (04-18-2018)
  #8
Old 04-19-2018, 10:14 AM
Andystoy Andystoy is offline
Currently: Not set.
Andystoy has a reputation beyond reputeAndystoy has a reputation beyond reputeAndystoy has a reputation beyond reputeAndystoy has a reputation beyond reputeAndystoy has a reputation beyond reputeAndystoy has a reputation beyond reputeAndystoy has a reputation beyond reputeAndystoy has a reputation beyond reputeAndystoy has a reputation beyond reputeAndystoy has a reputation beyond reputeAndystoy has a reputation beyond repute
Wink
Both the owners manual and a sticker on the clutch guard give you the optimum RPM which you can adjust up or down with the clickers on the clutch. The clicker comes on 3, increase the clicker up to the next number as you increase altitude as necessary or decrease the number to reduce RPM as you decrease in altitude.
If you find that your sled over revs at altitude you may need to add pivot weight or buy a clutch kit. Imo.
The Following User Says Thank You to Andystoy For This Useful Post:
  #9
Old 05-07-2018, 01:00 AM
donbrown's Avatar
Default
Copied from a clutch website:
The #1 way to keep clutch heat to its lowest is to have correct engine speed when full throttle – 7900. Lower or higher than 7900 the temperatures soar. Both over or underrev, the belt ceases to move across the face of the primary clutch face.
Core Value - Lower heat by lowering part throttle engine speed. So when (example) poking along at 40mph on the hardpack, from this snow area to softer snow area, lower heat will be at 6200 rpms instead of 6700 rpms.
__________________
  #10
Old 05-07-2018, 04:21 AM
greenthumb greenthumb is offline
Currently: Not set.
Basic Member
greenthumb has a reputation beyond reputegreenthumb has a reputation beyond reputegreenthumb has a reputation beyond reputegreenthumb has a reputation beyond reputegreenthumb has a reputation beyond reputegreenthumb has a reputation beyond reputegreenthumb has a reputation beyond reputegreenthumb has a reputation beyond reputegreenthumb has a reputation beyond reputegreenthumb has a reputation beyond reputegreenthumb has a reputation beyond repute
Default
Here is a dyno that I've seen that varies slightly from the one previously posted. It's not mine.
The Following User Says Thank You to greenthumb For This Useful Post:
donbrown (05-07-2018)
  #11
Old 05-07-2018, 10:00 AM
BIG JOHN's Avatar
BIG JOHN BIG JOHN is offline
Currently: making Summits bettersince 1997
BIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond repute
Click Here to Register
The Following 2 Users Say Thank You to BIG JOHN For This Useful Post:
Daag44 (05-08-2018), ZRP Engineering (06-25-2018)
  #12
Old 05-08-2018, 12:11 AM
donbrown's Avatar
  #13
Old 05-08-2018, 10:00 AM
Matte Murder Matte Murder is offline
Currently: Finally getting some rides in!
Matte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond repute
The Following 3 Users Say Thank You to Matte Murder For This Useful Post:
FEZ (05-08-2018), kanedog (05-13-2018), toms (05-08-2018)
  #14
Old 05-08-2018, 04:24 PM
FEZ FEZ is offline
Currently: Mechanic for and Advisor to SHR
Basic Member
FEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond repute
  #15
Old 05-09-2018, 07:55 AM
BIG JOHN's Avatar
The Following User Says Thank You to BIG JOHN For This Useful Post:
donbrown (05-09-2018)
  #16
Old 05-09-2018, 10:37 AM
donbrown's Avatar
  #17
Old 06-06-2018, 09:48 PM
Dynamo^Joe's Avatar
Dynamo^Joe Dynamo^Joe is online now
Currently: talking about clutching
Dynamo^Joe has a reputation beyond reputeDynamo^Joe has a reputation beyond reputeDynamo^Joe has a reputation beyond reputeDynamo^Joe has a reputation beyond reputeDynamo^Joe has a reputation beyond reputeDynamo^Joe has a reputation beyond reputeDynamo^Joe has a reputation beyond reputeDynamo^Joe has a reputation beyond reputeDynamo^Joe has a reputation beyond reputeDynamo^Joe has a reputation beyond reputeDynamo^Joe has a reputation beyond repute
The Following 6 Users Say Thank You to Dynamo^Joe For This Useful Post:
Adam12 (06-07-2018), donbrown (06-07-2018), kfa670 (07-01-2018), sledhead_24_7 (06-07-2018), toms (06-07-2018), Wheel House Motorsports (06-07-2018)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Optimal track run-out Thread Starter — Hbmtr Forum — Snow bikes Replies — 13 Last Post — 02-16-2015 06:26 PM
Thread — Optimal M5 RPM? Thread Starter — smv sledhead Forum — Arctic Cat: M Series Replies — 4 Last Post — 03-04-2013 08:32 AM
Thread — New OPTIMAL Combustion Chambers! Thread Starter — StoxResearch Forum — Performance/Modified Replies — 40 Last Post — 10-25-2010 08:34 AM
Thread — 2010 optimal/desired RPM Thread Starter — hatchers Forum — Arctic Cat: M Series Replies — 6 Last Post — 01-15-2010 01:49 PM
Thread — What is optimal rpm for m8 with twins? Thread Starter — Alberta Sledder Forum — Arctic Cat: M Series Replies — 16 Last Post — 01-02-2010 04:32 PM
no new posts
