Upgrade to Premium
Polaris: GEN 2 1999-2001, all models in the Gen 2 chassis
Reply
  #1
Old 11-11-2017, 09:57 PM
MT-BOONDOCKER MT-BOONDOCKER is offline
Currently: Not set.
Basic Member
MT-BOONDOCKER has a reputation beyond reputeMT-BOONDOCKER has a reputation beyond reputeMT-BOONDOCKER has a reputation beyond reputeMT-BOONDOCKER has a reputation beyond reputeMT-BOONDOCKER has a reputation beyond reputeMT-BOONDOCKER has a reputation beyond reputeMT-BOONDOCKER has a reputation beyond reputeMT-BOONDOCKER has a reputation beyond reputeMT-BOONDOCKER has a reputation beyond reputeMT-BOONDOCKER has a reputation beyond reputeMT-BOONDOCKER has a reputation beyond repute
Default 2000 rmk 700 bog problem
I have an 2000 rmk 700 with crankshop twin pipes, factory carbs with pods on them while riding the thing bogs till you get it up to 5500 rpm and will only run up to 7000 rpm was wondering if anyone had an idea of how to fix it. Thanks in advance
Last edited by MT-BOONDOCKER; 11-11-2017 at 10:00 PM. Reason: 2000 rmk bog problem
Rate this post: Yes | No
  #2
Old 11-12-2017, 08:58 AM
TRS's Avatar
TRS TRS is online now
Currently: Waiting for winter
TRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond repute
Default
What have you checked or cleaned?
  #3
Old 11-12-2017, 11:34 AM
retiredpop retiredpop is online now
Currently: Not set
retiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond repute
Default
It could be carburetor related or clutch related or a combination of both so more info is needed as to what you have done. Carbs cleaned and adjusted properly including proper jetting for pipes? Clutches cleaned and parts replaced if needed? Belt deflection and belt to primary sheave clearance okay? Did this run okay previously? Were you the one who put on the twin pipes?
Air pods never a good idea in my opinion because of pressure build up in engine compartment at speed and sucking in warm air.
Here is a fairly decent write up on Keihin carbs just for information purposes as to what portions of the carb affects things. https://www.duncanracing.com/TechCen...arbJetting.pdf
__________________
The older I get the better I was. In fact now that I think about it I'm a legend!
Haven't outgrown my 600 yet!
  #4
Old 11-13-2017, 11:34 PM
Currently: Not set.
Basic Member
Default
Someone else had put the pipes and pods on it before I had owned it. I did clean the carbs last year at this time but didn't do any adjustments to them.
  #5
Old 02-28-2018, 08:25 AM
NEWDUCK NEWDUCK is online now
Currently: one ski dreams
Basic Member
NEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond repute
Default
How are the clutches? I run an 01 rmk 700 in my hawk and I have fought a bottom end bog since day one. Ive also noticed pipe heat makes a HUGE difference with this engine. I was told these engines just done make much power down low. Im running a venom pink spring and that helps engage above the bog but im still fighting pipe heat. Are you running rack style carbs or the singe kehins?
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Fuel problem on 2000 700 RMK Thread Starter — oakster Forum — Polaris: GEN 2 Replies — 6 Last Post — 03-09-2013 01:17 AM
Thread — 2000 RMK 700 DEEP SNOW BOG Thread Starter — youngpolarisguy Forum — Polaris: GEN 2 Replies — 19 Last Post — 02-08-2011 01:04 PM
Thread — 2000 summit 700 bog Thread Starter — colotj Forum — Ski-Doo: S-2000 and older Replies — 2 Last Post — 01-18-2011 09:31 PM
Thread — 05 Liberty 700 occasional bog problem Thread Starter — mobsled Forum — Polaris Replies — 9 Last Post — 01-11-2008 06:20 PM
no new posts
