Upgrade to Premium
Polaris: IQ 2005-Current, all models in the IQ and IQ Raw chassis
Reply
  #1
Old 12-11-2017, 07:02 PM
peaceofwork peaceofwork is offline
Currently: Internet Rmkpro 800apprentiship
Basic Member
peaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond repute
Default 09 dragon trouble shooting
Before ordering a voltage regulator or other parts I want to try disconnecting the hand warmers and also disconnect the kill button at the plug and jump that and to test the teather, to test if the sled would then have spark. I got the plastics off the sled and am hoping some one can tell me what's up with this process, what colours are the kill button wires?
How do I identify the grip warmer wires?
My electrical skills suck so I'd sure appreciate a rundown on a few little tests before kicking out cash.
Rate this post: Yes | No
  #2
Old 12-11-2017, 07:08 PM
Basic Member
Default
Last day of running it started running crappy and stalling and taking a few minutes to restart. It made it back to the truck and now sitting cold it has good compression and no spark. New plugs change nothing, I pulled the voltage regulator and find bumps or bubbles on the bottom so I suspect it's been hot.
  #3
Old 12-11-2017, 09:20 PM
cascadesnowjunky's Avatar
cascadesnowjunky cascadesnowjunky is online now
Currently: doing the snow dance
cascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond repute
Default
A tale tell sign of a voltage regulator out is you can pull the ecu and look at the back and it will most likely be melted.
  #4
Old 12-11-2017, 10:07 PM
zalez's Avatar
zalez zalez is offline
Currently: #Quietly Ninja'd out!!
zalez has a reputation beyond reputezalez has a reputation beyond reputezalez has a reputation beyond reputezalez has a reputation beyond reputezalez has a reputation beyond reputezalez has a reputation beyond reputezalez has a reputation beyond reputezalez has a reputation beyond reputezalez has a reputation beyond reputezalez has a reputation beyond reputezalez has a reputation beyond repute
Default
The newer VRs fail with the symptoms you describe. It will run poorly, it will die and take awhile to start back up. This is an attempt to keep from frying the ecu. I would start there.
  #5
Old 12-11-2017, 10:50 PM
Basic Member
Default
looking at eBay aftermarket voltage regulators ? Or should I bite the bullet and just get the updated genuine Polaris 4013587 opinions ?
  #6
Old 12-14-2017, 01:10 PM
retiredpop retiredpop is offline
Currently: Not set
retiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond repute
Default
I don't know if the aftermarket regulators have the feature built in to them like the 4013587 Polaris regulator that if it fails it won't take out the ECU. I know there is quite a price difference between aftermarket and OEM regulators but ECU's are expensive. I'd go with the Polaris.
__________________
The older I get the better I was. In fact now that I think about it I'm a legend!
Haven't outgrown my 600 yet!
  #7
Old 12-14-2017, 01:17 PM
Basic Member
Default
i orderd the genuine polaris one a few days back and just praying the ecu will still be good
  #8
Old 12-14-2017, 06:08 PM
Default
Most likely your ecu is out also. If you continue to run them with a bad VR it takes out the ecu rather quickly. What leads me to believe this is you stated it now has no spark.
The Following User Says Thank You to cascadesnowjunky For This Useful Post:
peaceofwork (12-23-2017)
  #9
Old 12-15-2017, 07:14 AM
RMKillR's Avatar
RMKillR RMKillR is offline
Currently: Waiting for the trip to Lava Mountain
RMKillR has a reputation beyond reputeRMKillR has a reputation beyond reputeRMKillR has a reputation beyond reputeRMKillR has a reputation beyond reputeRMKillR has a reputation beyond reputeRMKillR has a reputation beyond reputeRMKillR has a reputation beyond reputeRMKillR has a reputation beyond reputeRMKillR has a reputation beyond reputeRMKillR has a reputation beyond reputeRMKillR has a reputation beyond repute
Default
Working a 09 dragon 800. Same symptoms. Had original VR. Pulled the ecu and inspected the back. Melted. Fried
__________________
09 DragonRmk 800 - non updated head no Polaris reflash fix kit pcV anodized rails & spindles rsi dumpers
02 edge 800 - xcr8 motor 144" 1.75 track SOLD
  #10
Old 12-22-2017, 12:37 AM
Basic Member
  #11
Old 12-22-2017, 01:06 AM
sledhed's Avatar
sledhed sledhed is offline
Currently: Last ride of the season 5/25/18...
sledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond repute
Click Here to Register
The Following User Says Thank You to sledhed For This Useful Post:
peaceofwork (12-22-2017)
  #12
Old 12-23-2017, 12:48 PM
Basic Member
  #13
Old 12-23-2017, 12:50 PM
Basic Member
  #14
Old 12-23-2017, 02:20 PM
zalez's Avatar
  #15
Old 12-23-2017, 10:54 PM
Basic Member
  #16
Old 12-24-2017, 10:20 AM
zalez's Avatar
  #17
Old 12-24-2017, 01:11 PM
Currently: Not set
  #18
Old 12-27-2017, 10:43 AM
XCaSSAULT XCaSSAULT is offline
Currently: Go Wild!
Basic Member
XCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond repute
  #19
Old 02-13-2018, 03:14 PM
Basic Member
  #20
Old 02-13-2018, 07:10 PM
Basic Member
  #21
Old 02-13-2018, 08:10 PM
Currently: Go Wild!
Basic Member
  #22
Old 02-15-2018, 04:55 AM
Basic Member
  #23
Old 02-15-2018, 05:06 AM
Basic Member
  #24
Old 02-19-2018, 12:06 PM
Basic Member
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — A little trouble shooting, questions Thread Starter — SWEETXPBEATCH Forum — Polaris: TURBO Replies — 15 Last Post — 04-26-2012 09:10 PM
Thread — DPM trouble shooting Thread Starter — eazyduzit509 Forum — Ski-Doo: S-2000 and older Replies — 7 Last Post — 12-21-2009 05:09 PM
Thread — trouble shooting 01 summit Thread Starter — rhino Forum — Ski-Doo Replies — 3 Last Post — 08-11-2009 11:23 AM
Thread — MCX Trouble Shooting Thread Starter — sledskiing Forum — Yamaha Replies — 28 Last Post — 01-23-2009 12:43 PM
Thread — m1000 trouble shooting Thread Starter — powder pounder Forum — Arctic Cat Replies — 8 Last Post — 04-10-2008 09:39 PM
