Upgrade to Premium
Reply
  #1
Old 12-04-2016, 07:15 PM
FatDogX's Avatar
FatDogX FatDogX is offline
Currently: ND. Meatball Crew / Polaris Ambassador
FatDogX has a reputation beyond reputeFatDogX has a reputation beyond reputeFatDogX has a reputation beyond reputeFatDogX has a reputation beyond reputeFatDogX has a reputation beyond reputeFatDogX has a reputation beyond reputeFatDogX has a reputation beyond reputeFatDogX has a reputation beyond reputeFatDogX has a reputation beyond reputeFatDogX has a reputation beyond reputeFatDogX has a reputation beyond repute
Default Little help with an IQR 600 HO
So I'm looking for a little help or at least maybe a direction to go with this.
I've got a IQR that has been fully trail converted with a 600 HO and PERC.
I purchased the sled as is and did not do the conversion myself, so that's why I'm looking for a little assistance.
Basically I went and had to re-jet and once I got everything back together I took it for a rip. Sled runs good but......after you get on it the tach goes all goofy and the Digatron EGT gauge goes goofy too.
The tach works at idle while you are parked but as soon as you take off it drops from 5 thousand RPM and bounces backwards and then goes to zero.
The dual EGT gauge also works at idle but when its under load, the gauge hits the warning lights then goes blank. So in a sense it is acting like the tach???
Also the PERC is now not working ???? This all happened after I re-jetted, so I'm guessing I pinched or may have pulled a wire, possibly a ground wire of some kind?????
I didn't have a chance to open it back up yet, but I was hoping for maybe a little tip or advice, so I'm not chasing dead ends!!
Big thanks to anyone!!!!
__________________
Polaris Pro RMK Axys 850 / 163
Polaris IQR 600
HD Street Glide with all kinds of goodies
Can Am Maverick X DS Turbo
Legend Enclosed Trailer (the toy box)
Rate this post: Yes | No
  #2
Old 12-04-2016, 09:06 PM
FatDogX's Avatar
Default
I went looking and found what appeared to be one of the PERC wires separated at a connection. Made the connection again but still no reverse????
Also, just noticed that I have no headlights either??? tail light works.......
__________________
Polaris IQR 600
  #3
Old 12-10-2016, 10:22 AM
omernikski's Avatar
omernikski omernikski is offline
Currently: On Snowest
omernikski has a reputation beyond reputeomernikski has a reputation beyond reputeomernikski has a reputation beyond reputeomernikski has a reputation beyond reputeomernikski has a reputation beyond reputeomernikski has a reputation beyond reputeomernikski has a reputation beyond reputeomernikski has a reputation beyond reputeomernikski has a reputation beyond reputeomernikski has a reputation beyond reputeomernikski has a reputation beyond repute
Garage
Default
When I did my conversion I had to change everything, even the voltage regulator. Tried using the 600r regulator and instantly blew the headlights out. I know that if the headlights are not working it will make the tach work from idle to about 3000 and then it goes bonkers. I can get you the part number off of the rr one I have and you can compare it. I had to order every piece of wiring and regulator for an rr in order to make everything work
  #4
Old 12-10-2016, 10:24 AM
omernikski's Avatar
Garage
Default
Also are you 100% positive you are running a 600rr cdi? The standard 600 fusion one has two ports and will not work
  #5
Old 12-10-2016, 11:38 AM
omernikski's Avatar
Garage
Default
CDI--2203802
AC REGULATOR--4011809
CHASSIS HARNESS--2411005
HOOD HARNESS--2410912
OIL LAMP HARNESS--2410902
ENGINE HARNESS--4011992
  #6
Old 12-10-2016, 04:58 PM
FatDogX's Avatar
Default
Quote:
Originally Posted by omernikski View Post
CDI--2203802
Thanks for the info!!!
The headlights are working fine and the sled runs fine. Its just this little stuff that came up after the re-jet, so I'm thinking it has to be something simple. I've got it over at a buddies right now and will take a closer look this week.
Thanks again!!!
__________________
Polaris IQR 600
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Polaris 2015 iqr 600 or cfi 800 light weight crank for sale and iqr parts Thread Starter — KCM Forum — Engine/Engine Parts (Swapmeet) Replies — 2 Last Post — 03-13-2015 03:43 AM
Thread — WTB pro rmk 600 pipe or twin 600 IQR pipes Thread Starter — Clarke_67 Forum — Pipes/Cans (Swapmeet) Replies — 0 Last Post — 03-11-2013 11:04 PM
Thread — Polaris IQR turbo, IQR 600 improver, 700 RMK and Assault Thread Starter — Corey223 Forum — Polaris (Swapmeet) Replies — 30 Last Post — 02-28-2011 02:03 PM
Thread — 06 IQR 440 and 09 IQR 600 f/s Thread Starter — PR Performance Forum — Racing Replies — 6 Last Post — 03-01-2010 01:18 PM
Thread — Does an '08 600 IQR pipe fit an '06 motor in an IQR chassis? Thread Starter — troylee Forum — Racing Replies — 1 Last Post — 04-03-2008 11:34 PM
no new posts
