Weight loss
SnoPro1000
283
115
I just bought a new cat and I’m wondering where there’s easy weight loss on them. Not including the can
SnoPro1000
283
115
Lol yes weight loss on myself would be a place to start.
Belt drive is up in the air I’m in that should I or shouldn’t i? Lol
SnoPro1000
283
115
It’s a 2018 mountain cat but posted here because most ppl don’t have the 2018 yet and have more experience with the older models
boondocker97
4,083
2,803
Billings MT
I see. That makes a difference as a few of the areas that would be addressed on the older proclimb have been upgraded already on the new mountain cats. And you don't have electric start, right? If you did there are big savings in the tank and seat. If not then your stock tank is already 9lb lighter than say a stock tank on a 2012 or 2013. Stock 2018 tunnel, shafts, and skid are all about as light as you can get without some major chassis re-design.
My list for weight loss only on a new mountain cat would be similar to what CO said in the ascender section: Polaris gripper skis, can, hood/headlight delete, strip panel foam, strip idler wheels, smaller tail light, no snow flap, no mountain strap, belt drive, conquer 280 track will save you 10lb but the 3" powerclaw performs so well I'm not sure it would be worth it. That is all the cheap, easy, bang for the buck stuff. After that it depends how much $/lb you are willing to spend. You can get Ti runners and hardware for the Polaris skis, Ti handlebars, Ti bolts all start running $2-300/lb.
SnoPro1000
283
115
Thanks for the reply,
I can’t believe how much harder and harder it’s gettinf to make them lighters without spending much $$
Manufactures are doing something right it seems lol
sno*jet
2,829
1,299
you could work it backwards and put a carbon hood from a proclimb on with some vented side panels. drop what 15 pounds? :face-icon-small-ton
